Tim, please explain difference between loop bandwidth and loop filter
bw.
I know, that lock range and hold range of phase loop are strictly
connected with
loop filter bandwidth, but maybe I am not familiar with proper
terminology.
It's more than just terminology. From your response to Vladimir's post,
it sounds like you're trying to apply a method by rote from a cook book,
or worse you're taking a text book as a cook book and applying example
results by rote.
You're implementing a closed-loop feedback system, like this drawing
(view with a fixed-width font):
ref ---->O---> loop filter ---> VCO ----o------> out
- A |
where the summing junction (the 'O') is your phase detector. The loop
filter, _by itself_ will have some poles (usual practice is to use an
integrator and some higher-frequency rolloff), and the VCO will act like
an integrator. Once you close the loop those poles will move -- you'll
still have the two or three significant poles that you started with, but
instead of having two integrators at s = 0 and a rolloff, now you hope to
have three stable poles that act in concert to make the loop behave like
a low-pass filter with a gain of exactly 1.
Lock range and hold range are connected with the loop bandwidth, but the
loop filter poles and gain is determined by the desired loop, so it's not
clear which you're talking about. I _suspect_ that you mean loop
bandwidth -- perhaps you should go back over the pertinent sections of
your book and see if the author makes the difference clear?
I see now, that I made a mistake during writing my 1st post: measurement
bandwidth was from 10Hz (lower limit of E4440A) to 100 kHz (1e5 Hz).
But integrated PSD from 10kHz to 100kHz is quite low and those values
are almost
identical.
So, timing jitter of my reference source should be reprinted by PLL to
divided VCO signal,
but phase noise of my VCO at 80MHz is 8 times grater, am I correct? And
reference phase noise and divided VCO phase noise should be almost
equal?
Yes, kind of. If you are well within the bandwidth of your loop, and if
your VCO noise is low enough to not contribute, yes. If your book is
decent then it'll show you how to do these calculations from first
principals. Basically at any given frequency your output noise will be
some constant times your VCO noise and some constant times your reference
noise. As the frequency gets close to the carrier the VCO constant will
go down and the reference constant will go up in a predictable way -- but
to really calculate the phase noise at the output you need to know the
PSD of the noise from the VCO and the reference.
This is a cheap VCO from Minicircuits and it has much larger phase noise
than
reference.
I think that I should check my circuits and repeat all measurements.
That sounds wise.
Could you tell me, which methods of "traditional" multiply give me best
results?
I 'discovered' that mixing reference signal with retarded copy of this
signal can
produce a sum frequency with lower phase noise at output of mixer.
Using 3 mixers one can produce 80MHz from 10MHz quartz oscillator, but
between
stages signal must be amplified. This will degrade overall phase noise,
since 1/2 of noise power
inserted by amplifiers will be added to phase noise.
I'd have to sit down to do the analysis, which I'm not going to do for
free on a newsgroup, but in general an amplifier can give you lower noise
than an oscillator. If you _really_ wanted to get the noise down you'd
amplify the heck out of the 10MHz reference with the lowest noise,
highest power amplifier that you could get away with, run the result
through a crystal filter, run _that_ through a varactor multiplier, and
then use a multi-stage bandpass filter to pick out the 80MHz.
Even just amplifying at 10MHz and driving a diode multiplier from your
reference, then filtering for the 8th harmonic should give you a clean,
if low-level signal.
Neither of the above methods is a sensible way to design a product in
2008 (1968 maybe, but not 2008). But if you just can't trust your
measurements, it may be a good way to verify the sanity (or insanity) of
your test set up.
Tim Wescott
Control systems and communications consulting
http://www.wescottdesign.com
Need to learn how to apply control theory in your embedded system?
"Applied Control Theory for Embedded Systems" by Tim Wescott
Elsevier/Newnes,
http://www.wescottdesign.com/actfes/actfes.html
