Low voltage rectification
Discussion in 'Electronic Design' started by James, Jul 20, 2007.
  1. James
    James Guest
    Hi All,
    I would like to rectify a signal with peak voltages in the range of
    50mV to 100mV. Are there any diodes that will start to conduct in
    this voltage range? Any other options besides a diode, I need it to
    be a passive device.
    James
  2. Winfield
    Winfield Guest
    You could step up the voltage with a transformer and rectify it.
  3. Mook Johnson
    Mook Johnson Guest
    How do you define a passive device. Since a diode is a considered a passive
    device is a transistor a passive device too.
    An opamp based active rectifier circuit would fit the bill perfectly.
    Otherwide gain the signal up with transistors (common emitter,etc) and
    rectifiy that, then attenuate to the original levels.
  4. If it is not to power something, then use active rectifier:
    opamp
    Uin ----------- + diode
    out ----a k----------------- peak rectified
    [ ] R === C
    The voltage on C will equal the posivie peak voltage of Uin.
  5. feebo
    feebo Guest
    I would say you need to abandon the idea of doing this "on the cheap"
    with a passive setup.
    Even though you seem to class diodes as active components, I don't
    know of any that will conduct this low - let alone what you are going
    to do with the signal once you have removed the diode "voltage".
    Chances are anything that will is gonna be mil-spec and/or hideously
    expensive/unobtainable. Germanium stuff can come down as low as 180mv
    but this is still way over what you are after.
    google "precision rectifier" there's plenty out there and depending on
    the opamp, they can work in this formation (i.e as a rectifier) down
    to a few micro-volts (some even lower)
    the first thing that came up for me here was
    http://sound.westhost.com/appnotes/an001.htm
    which gives a nice precision full wave rectifier circuit which you
    could construct for <$5 at a one-off price - Pay attention to the
    conclusion on this page - I think you will find it encoraging.
  6. MooseFET
    MooseFET Guest
    The "backwards diode" conducts at very low voltages. Nobody makes
    them any more because active rectifiers are commonly used today.
    http://www.answers.com/topic/backward-diode?cat=technology
    You can bias a normal silicon diode part way on and rectify small
    waveforms that way. The result is not very accurate.
    An ALD110800 with its gate hooked to the drain is fairly nonlinear
    near zero volts so it would also rectify.
  7. Eeyore
    Eeyore Guest
    Copper oxide rectifiers used to be fitted to the likes of VU meters.
    What kind of reverse voltage does it need to withstand ?
    Graham
  8. feebo
    feebo Guest
    further browsing turned up this very concise little page on precision
    rectifiers with single opamps which further reduces your
    cost/complexity.
    hant tried any of these - experienced eyes in this group will no doubt
    be able to comment on particular solutions to greater improve
    everyone's knowledge... gentlmen; the floor is yours.
    http://www5b.biglobe.ne.jp/~houshu/synth/Fwr0306.GIF
  9. John Larkin
    John Larkin Guest
    "no forward tunnel current" is not exactly correct. A back diode is a
    tunnel diode with a low Ip.
    Several people still make back diodes. They are photolithographically
    fabbed on germanium, unlike the classic/horrible tunnel diode fab.
    Back diodes are still the lowest noise unbiased RF detectors.
    http://www.microphase.com/military/detectors.shtml
    http://www.mpulsemw.com/Tunnel_Diode.htm
    (I think the Ip's are uA, not mA)
    http://ecommas.tycoelectronics.com/...SERIES3pdfEnglishENG_DS_2085_SERIES_3.pdf
    John
  10. The first question is what is this for? Is it RF detector or something
    else? Is it a measurement circuit? How accurate?
    50...100mV is not a very small voltage per se. A conventional small
    signal Shotky diode will have the impedance at the order of 100k at this
    range.
    Vladimir Vassilevsky
    DSP and Mixed Signal Design Consultant
    http://www.abvolt.com
  11. There are some diodes that have significant rectification in
    this voltage range. These include some very low voltage
    Schottky types.
    Here are some data sheets for low forward drop Schottkys, as
    examples:
    http://www.micrometrics.com/pdfs/SD_ZeroBiasDetector.pdf
    http://www.advancedsemiconductor.com/pdf/diodes/ZeroBiasSchottkyDiode.pdf
  12. Jim Thompson
    Jim Thompson Guest
    With lower resistance values and high GBW OpAmps I've used the
    following up into the MHz range...
    http://analog-innovations.com/SED/FullWaveRectifier.pdf
    ...Jim Thompson
  13. Use a synchronous rectifier.
    Many thanks,
    Don Lancaster voice phone: (928)428-4073
    Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
    rss: http://www.tinaja.com/whtnu.xml email:
    Please visit my GURU's LAIR web site at http://www.tinaja.com
  14. Eeyore
    Eeyore Guest
    Wow ! Some of those have useful reverse breakdown voltages.
    Whereas those don't. The usual problem with them it seems.
    Graham
  15. They are all just nonlinear resistors. Changes to the
    process move the nonlinearities around a bit.
  16. Eeyore
    Eeyore Guest
    Since when is synchronous rectification passive ?
    Graham
  17. Jim Thompson
    Jim Thompson Guest
    I know. But, as most posters here, he probably doesn't know what he
    really wants, or couldn't find a canned solution in AoE ;-)
    ...Jim Thompson
  18. Spajky
    Spajky Guest
    look at this mine first upper schematics (slide C); it is a 70Khz IF
    amp for measuring signal strenght. (for TDA7000 IC)
    Last half of the schematic- passive part at the end:
    The right last 2 resistors provide current biasing two germanium point
    glass demodulator type diodes to the knee of conducting signal ..
    So, you can measure from few mV & up to 2V RMS signals..
  19. Robert Baer
    Robert Baer Guest
    The Esaki (tunnel) diode is the closest passive device able to do that.
