D
Don Y
We're looking into installing low voltage, under cabinet
lighting in the kitchen. I assume these are driven with
a (variable) constant current source? Or, PWM?
Regardless, I plan on locating a switched outlet atop
the cabinetry to power the "power source". Then, some
conductors down behind the cabinets terminating at
the underside for attachment to the LED strips.
I believe many of these power sources have support
for an intensity control. I would like to locate that
somewhere invisible, yet accessible -- most likely
alongside the LED strips on the cabinet undersides.
(we don't envision changing this often, once we've determined
the appropriate intensity level for our needs)
I assume this is just a pot? Is it operating at a low
voltage? (i.e., what Code ramifications pertain?)
Would a small gauge wire pair -- possibly in a shield -- be
sufficient?
Lastly, pointers to suitable products? (power + LEDs)
Thanks!
--don
sufficient?
Thanks!
--don
