M
Me
Hello,
I need a variation of a Low Voltage Cutoff circuit.
I have a ballast that runs on a 12V battery. When the battery voltage drops
below 10V, the ballast shuts off, opening the circuit. After that happens,
the battery voltage rises due to lack of load, turning on the ballast, which
in turn drops the voltage and shuts off the ballast. This turns into a
vicious cycle.
I need to create a circuit that cuts off the voltage when the ballast opens,
(or when the battery voltage drops below a preset value, whichever is easier
to create), and stays cutoff, until I hit a Reset button.
Any ideas on the simplest approach?
vicious cycle.
