low voltage buffer
Discussion in 'Electronic Design' started by jutek, Feb 10, 2006.
  1. jutek
    jutek Guest
    Hello
    I describre my problem below and hope you'll help me.
    I am working on low power LDO. First i did simulation with simple one
    stage OTA (nmos input) plus power PMOS and feedback.
    The lowest Vdd is 1.3 so PMOS has to be quite big to drive 100mA. OTA
    has big output resistance, when working with low bias current and it
    causes, the parasitic pole of output resistance and pmos input capacity
    is in low frequecies. It deteriorates GBW, load regulation and so on.
    I want to use voltage buffer to send this pole to higher freq. I used
    simple pmos or nmos source follower but it's not efficient to fully turn
    on or turn off this transistor.
    So i used the same OTA in the buffer configuration. Its characteristic
    is ok, the slope 1. It repeats input voltage to output. But the problem
    is with low Vdd. It's 1.3V and i need about 0.3V at the output to drive
    100mA from pass device. This inut voltage causes, the inputs transistor
    (nmos) are cuttoff so the output resistance is big.
    With low load conditions everything is all right. Transistors work in
    saturation and output resistance is low.
    Could you recommend any tuning or circuit which will work fine?
    regards
    jutek
  2. jutek
    jutek Guest
    hi
    i don't know what's the matter. did i ask a school question again?
    sorry for that, but i can't find the solution.
    please, help if you can
    regards
