[email protected]
I have a schmidt hub generator and I would like to use it to power a 3W
Luxeon Star, if possible two of them.
The Schmidt hub generator is a AC generator that is built into the
centre of a front bicycle wheel. As the bike moves power is made. It
is very efficent and quiet.
The schmidt hub generator is a constant current source ( approx 500ma )
but it varies in voltage ( 6v to over 30v ) as speed increases.
The Luxeon LEDs are high powered versions of LEDs. To operate
efficently the 3W version requires 700ma-1000ma. It will light with
less current but it is not as bright. The voltage required is approx 3
to 4 volts.
The reasons these LEDs are better than standard halogen light bulbs are
that slightly more lumens per watt are made and that they have a longer
life..
A couple of people I have talked to have directly connected two 3W
Luxeon Star to either end of the AC supply so that one is on at a time
switching on and off very fast as the wheel spins. I think the LEDs
are in series with another diode to protect them from reverse voltage.
This approach does not give a bright light as the current is too low.
I have tried connecting a LED dynamics 03021-A-E-700 puck regulator
across the generator and using this to drive a single 3W Luxeon Star.
The light was not too bright until I got above 20kph. Then it was a
good brightness for about 10 seconds. After this the puck regulator
exploded. Presumably it was getting too much voltage.
What simple approach do you think would work for converting the
variable frequency and voltage of the generator to a constant current
in a suitable range to power the LED?
Would a puck regulator work, if I capped the voltage with a zener diode
or two?
to 4 volts.
life..
or two?
