I have a application in which i am switching low value resistors i. e. 0.1R, 0.2R, 0.4R etc to a unit under test.
I have come across a problem, track resistance and cable resistance which override the resistor values.
These are software selectable so need relays to switch them to the end circuit.
Is there any other way I can achieve this?
Ideally I need to keep the track lengths on the PCB the same or use them on planes so the resistance remains the same.
Any thoughts?
Best regards,
Rajinder
Any thoughts?
Best regards,
Rajinder
