Starbuckin
- Jan 22, 2013
- 10
- Joined
- Jan 22, 2013
- Messages
- 10
Greetings fellow circuit builders...
I built an outside/inside intercom system for my house using TL082's and LM386N-4's...
There is a TL082/LM386 pair inside the house for transmitting to an outside speaker. There is a TL082/Lm386 pair outside in a box on my fence that transmits back to my living room. I then have a "push to talk outside" switch that controls a dpdt relay that simply switches (alternates) between the two speakers being on or off.
When not pressing the switch, the outside circuit drives the indoor speaker and I have an excellent monitor of all sounds going on outside. When I press the switch, the inside speaker goes off and the outside speaker is turned on, so that I can talk to visitors outside.
This system has been in operation for about 7 years and I love it.
My point is that one pair of the circuit is OUTSIDE in an aluminum enclosure.
I have recently added more circuitry to the outside enclosure including 555 timers that drive L.E.D. arrays. Furthermore, all the chips have in their data sheets in their "Absolute Maximum Ratings" Operating temperature 0 degrees Celsius to about 70 degrees Celsius... So.... That means that the chips are not supposed to be operated below 0 Celsius (Which is 32 degrees F, or freezing).
In my location here in Kentucky, Winter temperatures often are far below the 0 degree Celsius rating.
My questions... What effect does low temperature have on these IC's??
Why are the ratings so generous when it comes to high heat (70 degrees C is 158 degrees F) but they can't be operated below freezing?? REALLY??
All these circuits are functioning just fine right now and it's about 15 degrees F outside right now.
It's obvious what the dangers are of operating a chip OVER the Max temp, rating... the chip is going to burn up...
But what about operating them under their low rating??? Is my 555 going to just 'lock up' and stop sending clock pulses to my 4017b and "freeze" the moving dot L.E.D. bar circuit that I built??
