Low resistance
Discussion in 'Electronic Basics' started by PW, Nov 14, 2008.
  1. PW
    PW Guest
    I need to measure the resistance of some motorcycle alternator coils
    They should be about 1.5ohm
    I have a cheap DVM, which is of little use at this value
    Is there a simple way to do this keeping in mind that I have Zero
    electoral knowledge.
  2. ian field
    ian field Guest
    The coils will have higher "resistance" (reactance) when AC current is
    applied, if you can find a wall wart with AC output (possibly a dial-up
    modem wall-wart) with approx' 12V output - hook it up with a dial or
    indicator bulb in series, a gross difference in brightness between any two
    identical windings would indicate a problem. You can also make use of your
    meter on its AC voltage range for a more precise indication.
    If you really do need an actual DC resistance measurement, the easiest way
    is to apply a regulated (and known) current to the winding and then measure
    the voltage developed, from there its a simple Ohm's law calculation: V/A=R.
    This topic comes up frequently on so the regulars
    have had plenty of practice giving advice.
  3. ian field
    ian field Guest
    The childish PHucker troll escaped from .
  4. Jamie
    Jamie Guest
    I bet you voted for Obama!
    http://webpages.charter.net/jamie_5"
  5. Jasen Betts
    Jasen Betts Guest
    use Ohms law.
    pass a known current like 100mA through the coil
    (eg use a 120 ohm resistor and a 12V supply) and measure the current
    using your DMM
    +12V ---[120]---[coil]---[DMM]---0V
    then disconnect the DMM and set the circuit up again and measure the
    voltage across the coil.
    (view with fixed pitch font - eg cut and paster into notepad)
    +12V ----[120]---[coil]---------- 0V
    `--DMM--'
    then divide current by voltage eg 150mV/100mA=1.50 ohms.
  6. For the DC measurement, if you have not a regulated current source, and
    if your DVM can not measure current, try the following:
    - buy a resistor between 1.5ohm to 15ohm, let's say R;
    - put it in serial with the coil;
    - put some DC voltage across the two resistors;
    - measure the voltage around the coil (Vc) and around the resistor (Vr)
    - compute coil resistance: Rc = (Vc)/(Vr)*R
    Warning: depending the DC voltage and the value of R, you have to
    correctly select the power of R. Do not put too much DV voltage. For
    example, if R = 4.7ohm and if you apply 5V, then power =
    4.7*(5/(1.5+4.7))^2 = 3 watts
    Olivier
