Low RDSon Logic CMOS Gate
Discussion in 'Electronic Design' started by Klaus Kragelund, Oct 1, 2012.
  1. Hi
    I need a CMOS gate with low voltage drop at about 30mA current source and sink. The tiny logic NL27WZ14 has 600mV drop at 32mA which equates to 18ohm RDS on.
    I am searching for a device with less than 5-10 ohms and it would need to be ok to parallel to get lower resistance. Also, it must not have to much crossover shoot-through (so probably schmitt trigger type) and must have low dissipation at high operational frequency (1-10MHz)
    Any one have a part in mind?
    Klaus
  2. hamilton
    hamilton Guest
    Please describe shoot-through.
  3. Been through some posts, but did not find it. Can you point me in the rightdirection? :)
    Regards
    Klaus
  4. Fred Bartoli
    Fred Bartoli Guest
    Klaus Kragelund a écrit :
    Mucho thanks for posting this...
    In an attempt to answer I had a look at a recent design and noticed that
    a 5V powered LVC14 escaped all the design reviews :-(
    It survived all the stress test: 27MHz switching, with PCB temp=100°C
    while driving a 250pF Ciss Mosfet...
    How did you know ?-)
  5. I found maybe a slightly better one, the NC7SZ14. The device lists CPD of 24 (Power dissipation capacitance, but no information on the unit. Icc = Cpd * V * f.
    (page 5 of http://www.fairchildsemi.com/ds/NC/NC7SZ14.pdf)
    I guess it's in pC (pico coloumb), which corresponds to 100uA/MHz.
    Regards
    Klaus
  6. whit3rd
    whit3rd Guest
    One can use discrete complementary MOSFETs to make a CMOS-like inverter,
    of course. Ferrite beads can help with the shoot-through problem, your
    frequency of interest seems low enough not to care. It may matter what
    voltage you're powering from, as well. At 5V, there's more options than
    at 2V.
  7. Hi Jim
    Thank you for taking time to elaborate on this ;-)
    The email is:
    It is valid and hotmail spamfilter works, I hardly get spam any more...
    Regards
    Klaus
  8. That's a secret ;-)
    Funny how some circuit work when they are not supposed to and other circuits that look clean and nice has "gotchas"....
    Cheers
    Klaus
  9. I have 3.3V, can make 5V if I need to. This is for a high efficiency device, so any powerloss is critical. Shoot through if a FET pair can easily go up to several amps, which won't be noticed if you are not looking.
    Cheers
    Klaus
  10. Fred Bartoli
    Fred Bartoli Guest
    The unit is pF.
    Multiply by 1/2 Vsupply^2 and you have the energy quantum lost at each
    switching.
    Total power loss is PL = f x Cpd x Vsupply^2
  11. Nico Coesel
    Nico Coesel Guest
    Maybe look for a MOSFET driver chip.
  12. Guest
    http://www.intersil.com/en/products...ches/switches-muxs-crosspoints/ISL43L210.html
    (from John Devereux, earlier this year)
    Break-before-make.
    DigiKey had competing parts, too.
  13. Jamie
    Jamie Guest
    Talking about Digikey, they getting any better at stocking more of what
    they advertise? I have been leaning towards the other parts suppliers
    lately..
    Jamie
  14. Guest
    that was my first thought, something like fan3111, but..
    datasheet doesn't say what the dropout is, it maybe a bit slow for
    10MHz and who
    knows how much power it will use
    maybe a buffer/linedriver
    -Lasse
  15. Guest
    HC or HCT ?
    http://www.ti.com/lit/ds/symlink/sn74hct04.pdf
    http://www.nxp.com/documents/data_sheet/74HC_HCT04.pdf
    TI <3mA per pin at 2.4Vin
    NXP <590uA at 2.9Vin
    that shouldn't be a problem driven with a 3.3V output
    -Lasse
  16. whit3rd
    whit3rd Guest
    A dual MOSFET (P-channel/N-channel pair) like Rohm EM6M2 can easily handle the task.
    If you add a couple of 2 ohm drain resistors, it limits the shoot-through to well under one
    amp, but the output resistance only gets two ohms drop (still well below your 5 ohm
    goal for 3.3V power supplies). Note the PFET has rather high capacitance, that's
    required to get the low on-resistance.
    For best shoot-through limit, it gets complicated (you need something more than
    a logic drive, it takes turn-on delayed but turn-off prompt).
  17. ...Snip..
    The EM6M2 has 1nC of gate charge. Running that at 5V and 200kHz will consume 1mW. I was trying to reduce the gate charge losses by using a logic IC
    On that subject, anyone know the value of the gate charge for a run-of-the-mill gate inside a chip?
    Regards
    Klaus
  18. Guest
    For sure there are higher Rds(on) parts with lower capacitances,
    right? I was just throwing out an extreme example, since I'm an
    extremist :).
    I suspect the make-before-break convenience, integration, and
    capacitances in other switches will be attractive.
    I didn't have time to screen parts--I mostly have to post and run
    these days.
    James
  19. Guest
    I've destroyed 74AC parts that way. Smoked 'em.
  20. Guest
    HCT stuff isn't tuned for speed so has little crossover current (none,
    ideally). AC logic is a whole different kettle. Better decouple AC gates
    well. ;-)
