Low pass filter hookup
Discussion in 'Electronic Basics' started by [email protected], May 18, 2008.
  1. Guest
    Hello,
    I created a low pass filter in orcad and trying to put theory into
    pratical. The circuit output is always showing the input at about one
    third the pk-pk voltage even at 30kHz and more, this is suppose to be
    a 3kHz lpf.. I think the wiring might be wrong.
    I took the black pin of the function generator as the ground reference
    point. Use two 6v batteries for positive and negative voltage and
    place the middle of the batteries at the ground reference point from
    the function generator.
    Here is a link with my circuit and a picture:
    http://www3.sympatico.ca/lerameur/LPF/
    Or does any one has a specific instruction to a simple active LPF and
    wirinf connection, maybe I can start from there.
    I tested my OP Amp, and that is not the problem.
    k
  2. Bob Eld
    Bob Eld Guest
    As was mentioned, the LM339 is a comparator not an op amp. Use an LM 324, LF
    347 or a TL084 or equivalent op amp. The 339 will probably oscillate if
    used as an op amp and it needs a pull up resistor on the output of each amp
    section. It ain't the right animal. Be sure to check the pin out, these amps
    are very different than a 339.
    Secondly there is no true dc path to ground for the amps except through the
    generator. Place a 10K resistor from the input point on R5 to ground. This
    will establish amplifier bias even when the generator is un-hooked.
    Bypass the plus and minus power rails to ground with small caps, 0.1uF is
    ok.
    The circuit should work ok with proper amps as a six pole low pass filter
    with 36db per octave cut off slope.
    I calculate a cut off of 2kHz for two sections and 1364Hz for the first
    section. This will be sloppy filter with a main cutoff at 2kHz. How did you
    figure 3kHz?
  3. Phil Allison
    Phil Allison Guest
  4. Eeyore
    Eeyore Guest
    Same here.
    Graham
  5. neon
    neon
    1,325
    Oct 21, 2006
    linear filter means it must be linear a 10v bus will take the output to 5 and swing from therewant to get rid of the dc adda cap in series. and finaly an lm330 is a comparator and fast you will never get but square wave output .
