P
Phil Hobbs
I'm building a test jig to measure the noise floor of my antenna-coupled
tunnel junctions. This is slightly awkward to do by cobbling test
equipment, because they're only a few hundred ohms, and I need to be
able to measure their noise under bias. I'm rooting through my Lista
drawers full of ten-year-old parts for something to slap together.
So I have this nice way-way-sub-poissonian bipolar current source, with
1-Hz voltage feedback so that I don't blow anything up. Works groovy.
Now I'm building a low-noise amplifier to do the noise measurement.
It's a discrete diff amp made from Rohm 2SD786 BJTs, running at a
voltage gain of about 250, with an inverted cascode on each input
transistor to deal with the huge C_cb while bringing the signals out
near ground. There's an LM6361 as the output stage, with overall
AC-coupled feedback to get a gain of 1000, and an auxiliary bias
correction loop dumping a bit of current into one of the collector loads
to keep delta V_BE of the diff stage at zero. Should work fine
sometime tomorrow.
Which brings me to my actual question: Are the 2SD786 and 2SD737 still
the BJT noise champions at low source resistance?
Cheers,
Phil Hobbs
sometime tomorrow.
Cheers,
Phil Hobbs
