W
Werty
You are NOISE .
There is nothing new in analogue Op Amps and
there never will be .
The fast lane is to simply search existing ,
leading applications , and
then merely buy what they used or
compromise a bit to hit your target .
First you must duplicate that app'
Then mod circuit for your objective
Some ppl use a known fault in an
I.C. to throw you off course .
CD4___ . T.I. , long ago made
CD4007 ? . If you held both CLK and
RESET pins together , it did not act proper.
Burr Brown Res' used this in an oscillator
"722" and got burned ( Sole sourced = bad)
Thus , in your characterization of their
application of that I.C.
, you must consider this and purposely
"push" the envelope , to learn
if their are any anomolies , not mentioned
in SPECs .
I do E.E. . I make profits .
in SPECs .
