Low frequency Amplifer
Discussion in 'General Electronics Discussion' started by Twodio, May 17, 2013.
  1. Twodio
    Twodio
    35
    May 17, 2013
    Hey guys.
    I'm trying to construct a circuit that can convert litles vibrations into a more higher.
    I want to use only one transistor NPN one LED somes resistors, one capacitor, one electreto mic and one speaker.
    The problem is when i try put working doesn't happen nothing.
    Someone can help me or pass me another way to make.
  2. BobK
    7,682
    1,688
    One transistor is unlikely to get you from an electret mic to a speaker. Show us your circuit.
  3. Twodio
    Twodio
    35
    May 17, 2013
    The schematic of my circuit is one like this
    [​IMG]
    With two NPN transistors and one adapted LED that doesn't disturb the power traffic
  4. (*steve*)
    25,496
    2,837
    The comment about the LED doesn't make any sense (especially since there is no LED there).
    the 220k resistor should be connected between the base and the +ve terminal of the battery.
    This circuit will draw significant power (it's class A) *and* a DC current flows through the speaker (which is generally a bad thing)
    edit: google for the LM380 or LM386 (depending on the power you require).
  5. Twodio
    Twodio
    35
    May 17, 2013
    Exist one class B or C ?
  6. BobK
    7,682
    1,688
    Not necessarily, the way it is shown, it will have negative feedback to stabilize the bias. Otherwise, an emitter resistor is needed.
    Edited to add: I don't think you get anything like 200mV out of an electret mic, more like 5mV. And an electret mic needs a power connection, if it is not built in.
  7. CDRIVE
    4,960
    652
    May 8, 2012
    The bias resistor can be split into two resistors with their common node bypassed to gnd with a cap. This maintains bias stability while removing negative signal feedback. ;)
    Chris
  8. Twodio
    Twodio
    35
    May 17, 2013
    Thank you everybody that try help me.
    I'll try simulate first until get something higher that 250mA and produce some loud.
Similar Threads
Loading...
