Jeff Niles
I need to build a circuit that will charge a 100uF capacitor to 240V
with a _10 Hz_ pulse, and then have the cap hold the charge for at
least 24 hours. The purpose is to establish a static field via a pair
of plate electrodes connected in parallel with the cap.
I am thinking of an LM555 feeding a 10% duty cycle pulse to an 8R:1K
miniature audio transformer, or two of the latter with output sides
wired in series to increase voltage. The cap would be connected across
this, and isolated from the charging circuit with a switch after
charging.
Can anyone please any suggestions or improvements regarding this type
of circuit?
Also, what would be the best type of cap to use?
Thank you,
Jeff Niles
charging.
of circuit?
Thank you,
Jeff Niles
