Joerg
Ok guys, normally I'd do this discrete and maybe I will again if there
ain't anything reasonable (<$5/1k) and available:
Photo diode receives analog signals modulated onto fiber. Modulation
frequency range up to 100MHz. The downside is that this time I must go
from full scale down to DC and that level must be accurate or at least
stable. A mV or two in offset would be ok but drift should be a lot
lower. It's going to be the usual current input thing.
What's you preference for a low noise amp in a situation like that?
TI's THS4xxx series looks good but still a bit high in terms of noise.
The ideal thing might be an AD603 without its input attenuator but these
don't come bare bones. Analog doesn't list noise in the paramatric table
which makes a search cumbersome and their photodiode design tool which
does include noise ends at 100kHz :-(
+/-12V supplies would be nice but it's all flexible at this point.
