T
Tim Shoppa
The 8038 sine wave VCO has been around for a good chunk of a century.
Probably about the same for the XR-2206. But their distortion is in the
half-percent range, and I'm desiring a low distortion sine wave VCO
with distortion in the 0.01% range (and will not complain if it's
better).
For my particular project, I need the center frequency to be somewhere
in the low audio range (20 Hz to 1kHz would be great.). I'm not picky
about the exact center frequency. I also have very undemanding needs
for the tuning range: +/- 10% would be enough, and maybe just a few
percent would be better.
DDS isn't particularly desirable because the control voltage is a
voltage, not a number. I know I could add an A/D to make it a number,
but my feeling is that this is going down the wrong road.
Wien bridge oscillators can certainly meet the distortion needs, but is
there a "good" way to control the frequency (even over a limited range)
with an external voltage? Again, don't get into digitally-controlled
pots. I'm thinking something more like photocells here. But wouldn't I
need a matched pair of photocells? If the variable R were only a small
part of the total R, matching wouldn't be all that important, right?
Since my frequency range is so narrow, is a 8038 or XR-2206 followed by
many poles of low-pass filtering out of the question?
Tim.
better).
Tim.
