Low current zener diodes?
Discussion in 'Electronic Components' started by Paul Ciszek, May 11, 2007.
  1. Paul Ciszek
    Paul Ciszek Guest
    Does anyone sell Zener diodes that hit the constant voltage part of their
    I-V curve at currents of less than 5mA? I have a datasheet from
    Microsemi that gives the specs of 1N46xx diodes, and lists a Zener test
    current of 250uA. These would be great, except that no one seems to
    actually sell them--it's all "call for quote". Are low-current Zeners
    only manufactured by special order?
  2. Joerg
    Joerg Guest
    Pretty much. Most diodes a just "measured into" a low current by going
    into the knee. IMHO not a good thing. Central Semi is pretty good:
    http://www.centralsemi.com/
    Talk to Charlie Moller, very helpful.
    Long story short, most of the time when clients call in with a zener
    tolerance issue I redesign their units to accept the LMV431 and similar
    chips. Unless the few cents extra aren't in the cards, then we have to
    select a new zener.
