Lopt
Discussion in 'Electronic Repair' started by M.Joshi, May 2, 2005.
  1. M.Joshi
    M.Joshi Guest
    Can an LOPT be transferred from one television to another (Matsui 20T
    -> Philips CP-90)
  2. kip
    kip Guest
    No
  3. S
    S Guest
    If they are the same make/model of flyback they could. but chances of that
    are remote since you can't make(gouge) money replacing parts if the parts
    are interchangeable...
  4. Art
    Art Guest
    If they are the same chassis, using the same yoke and crt they should
    interchange without amy major problem. the P/N should be the same on the old
    item as the one you are trying as a sub. Not a good idea to try and swap
    LOPT between manufacturers or even from a small deflection tele to a larger
    one, just will not function correctly.
