Loose Radio Earphone Jack
Discussion in 'Electronic Repair' started by Buck Turgidson, May 11, 2006.
  1. I have a Sony sports radio, and I thought the earphones were bad because I
    always had to jiggle the cord near where it plugged in I replaced the
    headphones, but I have the same problem with the new pair, although it is
    not quite as bad as the old pair.
    So, I am guessing that the jack receptacle itself is loose, not the wire.
    Is there a way to fix this? Can I wrap alum. foil around the male end? Or
    tape? I know it is an inexpensive radio, but if there is a simple way to
    fix it, I'd love to forego the expense of a new one.
    Thanks.
  2. It may be bad solder connections between the headphone jack and the
    circuit board inside. This will require someone to open up the
    unit and resolder the connections. It's an easy job.
    Could also be the spring pressure of the contacts inside the jack but
    it may be necessary to replace the jack.
    DO NOT attempt to do anything like aluminum foil. You'll may end up
    shorting it out and causing more damage.
    --- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
    | Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
    ignored unless my full name AND either lasers or electronics is included in the
    subject line. Or, you can contact me via the Feedback Form in the FAQs.
