Looking to drop 6 volts dc to 4.5 volts dc
Discussion in 'Beginner Electronics' started by .D.E, Sep 28, 2006.
  1. .D.E
    .D.E Guest
    I'm looking to add a mod to my pinball machine with a couple of led's and
    need to drop 6 volts dc down to 4.5 volts dc. Can anyone suggest which
    resistor to use?
    Thanks.
    _____________________________
    Later.
    Have a better one.
    D.E.
    To email me back, remove "forget.the.spam"
  2. R = (Vsupply - Vled) / Iled
    Good Luck!
    Rich
  3. No, due to lack of information. Suppose the LEDs do 4.5V when lighting, what
    current do they use? You'd realize that LEDs are current driven devices so
    the current can easily double while the voltage hardly changes.
    petrus bitbyter
  4. Al
    Al Guest
    If your LED is specified at 10mA, then get two diodes whose forward
    voltage is 0.75V at 10ma. Put them in series with your LED. If the
    supply voltage goes up and the current goes up, the forward voltage of
    the diodes will go up also thereby dropping more voltage across them.
    Thus the dynamic resistance of the dropping diodes serves as a voltage
    regulator. Really good diodes with a low dynamic resistance won't do.
    Al
  5. That diodes will work when you have a resistive load. But neither LEDs nor
    other diodes behave like resistors. Once more: You need to regulate the
    current, not the voltage. If the LED has been specified for 10mA at 4.5V
    you'll need a series resistor of (6-4.5)/10=0.15k that's 150 Ohm. Most LEDs
    are specified for 20mA or more. FAIK only low power LEDs require less.
    petrus bitbyter
  6. jasen
    jasen Guest
    yeah, if the current doubles the voltage may increase maybe 10%
    how's that going to help?
    it seems to me that regular resistors would work better,
  7. Al
    Al Guest
    If your current doubled for some reason, you have other big problems.
    Al
  8. Al
    Al Guest
    A series resistor is not a constant current source.
    And, this method is not for manufacturing millions of items. It's for
    solving a special home problem. Like I said, I do it and it works for
    me. No, I don't bake the circuit nor do I freeze it. And as I mentioned
    above, diodes with soft knees should be used.
    Al
  9. Al
    Al Guest
    The poster said his source voltage was 6 volts. Since he was using it to
    drive LEDs, I presumed, perhaps falsely, that it was a steady DC. He
    should have specified a range, such as 6Vdc +/- 0.5V.
    Is it a true DC as derived from a dry cell? Is it pulsating DC derived
    from either a half-wave or a full wave diode bridge? Does he have an LC
    filter on the output of the bridge? Or is it just a big rectifier across
    the bridge? Is there a linear regulator or a switcher involved? As
    someone else in this thread had suggested, it might be the output of a
    6.3V filament transformer that is rectified.
    All of these factors, and probably many others, would have to be
    considered.
    The brightness of an LED is a function of the current through it.
    Typically it specified to have a certain light output level at a
    specified current. You may increase or decrease the current as you will.
    The lifetime of the LED will depend on the current as will its light
    output. Even the specified current is just a normalization of the
    readings from a large sample. Your specfic LED may need more or less
    current for the specified light output.
    So, if the LED is specified to give a certain light output at 10mA at
    4.5V and if the source voltage is a constant 6V, I would use two diodes
    whose forward voltages are specified as 0.75V at 10mA to give me a 1.5V
    drop.
    The forward voltage drops of a typical 1N914 diode are shown as:
    Vf If
    volt ma
    0.6 3.0
    0.7 10.0
    0.8 30.0
    Two diodes in series would give me the approximate 1.4V drop close to
    what I would need.
    Al
  10. redbelly
    redbelly Guest
    That doesn't sound like it would work. Now you have an extra 0.1 V on
    the LED. The current could be easily double (or more) what is wanted.
    "Close to the right voltage", in an LED or any diode, just doesn't cut
    it in terms of limiting the current.
    And if the source voltage is NOT a constant, exact 6V, it's even worse.
    Resistors are the standard, simple easy way to limit current through an
    LED.
    Mark
  11. Jim Thompson
    Jim Thompson Guest
    Has anyone mentioned to just use a current source? Even 0.5V headroom
    would be adequate.
    ...Jim Thompson
  12. jasen
    jasen Guest
    Typically leds are specified with a voltage range for their limit current.
    get the curren right and the voltage will be somewhere in that range, it
    depends on the device and the environment.
    If that particulasr led is 4.4V with 10mA flowing through it it could with
    4.5V the current could be 30mA or more.
    And when they get warm, it drops, this can lead to thermal runaway.
    ordinary resistors consistently out-perform ordinary diodes as a LED
    current source.
    Bye.
    Jasen
  13. Al
    Al Guest
    Sigh! Yes, that's true. But I routinely use one or two diodes, depending
    upon current, to drop my 6Vdc battery down to a nominal 5Vdc that my
    circuits use. It works. What can I say? It's a cheap and dirty way of
    doing it for home projects.
    For example, I have a circuit which nominally draws 50ma during
    operation. Upon the needs of the project, a 200mA pulse (100mS) drives a
    latching relay. If I used a 20 ohm resistor to drop the voltage to 5Vdc
    during norminal operation, it would really screw up the circuit during
    the pulse as the series resistor would drop the voltage by 4V!
    So, tell me, how many components would you use to drop your 6Vdc to 5Vdc?
    Al
  14. ehsjr
    ehsjr Guest
    What someone else would use is irrelevant. You use
    whatever you want to meet the circuit requirements.
    Here's a possibility for your pulsed 200 mA.
    Substitute whatever you're using in place of the switch.
    +6 ----+-----o o--------+
    [20R] [5R]
    [50 mA Load] [200 mA Load]
    Gnd ---+----------------+
    For the LED circuit that was discussed a resistor
    is fine. For something that requires regulated 5,
    you can use an LDO like
    http://www.national.com/ds/LP/LP38690.pdf
    For something like a 4.5V toy motor, your diodes
    may be fine.
    Ed
  15. Al
    Al Guest
    You are correct!
    I was just using the 200mA load situation just to show how a resistor
    would not do the job. And, one should use what works in their particular
    situation.
    I've always wondered why the industry settled on 5 volts as the standard
    for TTL esp. since 6 volt batteries were so common. In the 60's I
    actually worked on a logic system which did use +6 and -6 volts for the
    logic. I can't remember if +6 was a one and -6 was a zero, or was it
    visa versa? For experimentation with this logic type, we actually used 6
    volt lead/acid batteries for power. We quickly learned never to short
    anything here!
    Al
  16. Daniel
    Daniel Guest
    When I did my electronics training in mid-70's, I can recall a cct that
    was part positive logic (1=-5V, 0=+5V) and part negative logic (1=+5V,
    0=0V).
    Just a little confusing.
    Daniel
  17. Guest
    If I understand your question correctly, most people makes voltage
    regulators out of Zener diodes. However, I suppose you could make a
    voltage regulator using a couple of LEDs although it probably wouldn't
    be as accurate.
    For information on how to do this look at instructions for doing it
    with a Zener and then simply adapt them for using LEDs instead. For
    information on making a regulator using a Zener, type in ZENER VOLTAGE
    REGULATOR in Google. Here's a couple of examples:
    http://www.allaboutcircuits.com/vol_6/chpt_5/7.html
    http://www.ycmou.com/st/Download/ALM/Zener Reg.pdf#search="voltage regulator zener"
