R
Robert Miller
I need to build a solar powered colloidal silver generator. To treat my
water on camping trips. As both a practical way to treat water for drinking
and for the
coolness factor of having built something practical that does not need
batteries.
I've built DC voltage multipliers before with the diodes and caps in a lader
fashon. They are not very efficient. So I know I need to build an RL
circuit.
then I guess I need a transformer to step up the voltage.
I would like to step the voltage up to at least 600 volts or as high as 2k
volts
I don't need much current. The device I use now is a simple three 9 volt
batteries in series with .999 fine silver for the cathode and for the anode.
I treat a solution of distilled water which I then pour into the water I'm
treating.
From what I understand the higher the voltage the more stable the silver
ions in sollution, and the greater the percentage of nano-meter sized silver
particles
which are the most effective at killing bacteria, fungi, and virus's.
At just 5 parts per million this sollution is said to kill bacteria in 4 to
5 minutes
with no toxic side effects.
This sollution will even kill pathogens like Anthrax, Small Pox, and
Malaria.
Thanks in advance for any ideas or input!
Robert Miller
and for the
batteries.
circuit.
volts
treating.
particles
5 minutes
Malaria.
Robert Miller
