Looking for wall adaptor power supply
Discussion in 'Power Electronics' started by Anon_LG, Jul 28, 2014.
  1. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    I need a wall adaptor so that I do not have to use batteries all the time. Does anyone have any suggestions for a supply, I work with CMOS 4000 series usually so I would like the supply to have a setting of 5 Volts and I need another output giving 9 Volts. The adaptor must be under £70. It needs to be able to work off 50Hz, 230 Volts. And would I make it myself no, I would not trust myself with something like this because it could fry my brains!
    It needs to be able to either output 9 Volts out of one output and 5 Volts out the other at the same time or I need 2 separate power supplies.
  2. Supercap2F
    Supercap2F
    550
    150
    Mar 22, 2014
    My best advice would be for you to google it. It's going to be hard to find a power supply that puts out 5V and 9V, you will mostly find stuff that puts out something like 0-30V or 0-12V etc. Or you could just get two wall warts, one 5V and one 9V.
    Regards
    Dan
  3. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Do you want a bench power supply or just a wall adapter? You can get "wall wart"-type switching power supplies with output current around 1A here for less than the equivalent of £20; just get a 9V one and a 5V one, or regulate the 9V down to 5V.
    Cheap switching supplies can be unreliable; if you can afford a bench supply like the one Adam linked to, it would be a worthwhile investment.
  5. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    The bench supplies seem rather expensive, I need it to be able to output 5 Volts and 9 Volts at the same time.
  6. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    Set it to 9V and use a 7805 regulator to provide the 5V rail from the 9V supply.
    Anon_LG likes this.
  7. shumifan50
    shumifan50
    580
    57
    Jan 16, 2014
    Unless you need separate grounds.
  8. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    I do not need separate grounds for what I am doing. Thanks Kris, I will get a 9V power supply and use a voltage regulator.
  9. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    You said less than £70.00??
    Adam
    Supercap2F likes this.
  10. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    I meant others.
