Looking for Vertical DC Socket for PCB
Discussion in 'Datasheets, Manuals and Component Identification' started by Mike Williams, Oct 30, 2014.
  1. Mike Williams
    Mike Williams
    4
    Oct 30, 2014
    Hi
    Just looking for 1 of these - I think it has 4 pins
    Any ideas
    I am from the UK
    Many thanks
  2. (*steve*)
    25,496
    2,837
    You may need to show us what the plug looks like. Off hand, I can't say I've ever seen one of these. Be prepared for it being a part manufactured especially for the company producing the board.
  3. davenn
    davenn Moderator
    13,833
    1,950
  4. Mike Williams
    Mike Williams
    4
    Oct 30, 2014
    Have a look at these photos
    [mod note: deleted all the excess images]
  5. (*steve*)
    25,496
    2,837
    I think Dave's first link shows the same part.
    Is it a for a Sony Vaio laptop (that would have been useful information)? If not, what is it for?
  6. Mike Williams
    Mike Williams
    4
    Oct 30, 2014
    Sorry, it is for a PC flat screen monitor - Samsung LS22A100
  7. (*steve*)
    25,496
    2,837
    OK, so it may not be one of the ones linked to by Dave.
    Can you measure the outside diameter of that plug?
    If you get a new socket, and assuming it fits the plug, your next task is to remove the old one and replace it. Do you have the equipment and skills to do that?
    And what makes you think that the socket is faulty?
  8. Mike Williams
    Mike Williams
    4
    Oct 30, 2014
    It is 6mm
    I am trying to fix it for someone else and they said that leading up to the fault, they said they had to wiggle the dc connection to get some life out of it
    I can solder (up to a point)!
    Do people have success with heat guns/hot air stations ?
  9. davenn
    davenn Moderator
    13,833
    1,950
    its a pretty standard plug/socket
    my HP laptop uses the same one
    if you cannot get it locally in UK from Farnell etc then you will have to go overseas to mouser or digikey in the USA or to one of those links I gave you earlier
