Looking for specs for a vintage HP Current Amplifier Model 1111A
Discussion in 'Electronic Repair' started by Engineer, Apr 19, 2007.
  1. Engineer
    Engineer Guest
    Hi, everyone.
    Can anyone point me in the direction of the specifications for Subject
    instrument. I've just refurbished one that I rescued from the
    dumpster, but I'm not sure over what frequency range it works - checks
    out good at 60 Hz, but what about audio frequencies?
    BTW, it consists of three pieces:
    1. a magnetic split-toroidal probe, plus coax cable,
    2. an electronics unit that drives a scope on the 50 mV/cm setting,
    and
    3. an old fashioned "wall-wart" p/s (before that term was in vogue!)
    - all built like a brick outhouse, typical of HP from that era.
    Cheers,
    Roger
    PS. I'd appreciate an email to "analogdino 'at' rogers 'dot' com" as I
    don't get back here often! Many thanks.
  2. DaveM
    DaveM Guest
    Nope, I ain't gonna reply to your email. You asked the question here, and you
    should at least have the courtesy to look for your answer here.
    OK, rant over.
    The 1111A has a rise time of 18ns. Accuracy in X10 mode is +-3%, in X100 mode
    is +-4%.
    Max AC current above 700 Hz is 50A p-p. Below 700 Hz, the max current is
    decreased by 1.4A/20Hz.
    Output impedance is 50 ohms.
    Noise is <100uA p-p, referenced to input.
    I guess you could estimate the upper frequency limit by figuring the bandwidth
    similarly to the way an oscilloscope's vertical bandwidth and risetime are
    related:
    Fmax(Mhz) = (0.35 / Tr(us))
    Based upon that formula, the Fmax of the 1111A is
    0.35/18000 = 194 KHz
    Of course, that's just a guess... you'll have to use some experimentation to
    determine its useful upper limit. But according to the risetime spec, it's
    surely capable of the full range of audio frequencies.
    HTH
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Life is like a roll of toilet paper; the closer to the end, the faster it goes.
  3. Engineer
    Engineer Guest
    Well, that's a relief... I only came back to see if my post went in!
    Dave, thanks for the info - now copied into my specs file. I'll run a
    test using an audio power amplifier into a 4 ohm load up to a few KHz
    and see what I get. Oh, and I'm glad you did not email me... I would
    not like accepting such an extravagant accommodation that I could
    never repay.
    Cheers (still),
    Roger
  4. DaveM
    DaveM Guest
    Good luck with your testing. You could repay by posting the results of your
    testing back here, so that if anyone else might be going through the same pains
    as you are would have the benefits of your work.
    Cheers!!!
    Dave M
    address)
