Looking for special dual voltage regulator.
Discussion in 'Electronic Design' started by Jamie, Aug 26, 2007.
  1. Jamie
    Jamie Guest
    A couple of times in the past while poking around the
    inners of some equipment. I ran across a low power
    IC with 8 legs tab style. I wish I wrote the numbers
    down.
    This IC, accepted the AC directly from the xformer..
    it had 2 inputs for the AC, the xformer was CT to common.
    2 outputs for filter caps which coupled to common.
    1 common leg, 1 control switch input leg and 2 outputs
    which gave you + and - regulated sources.
    I think the chip I was looking at last output 5 V + and -
    this was not a DC to DC converter.
    Apparently it has the bridge rectifier inside it with
    2 + and - linear voltage regulators.
    I would like to find the base part number for this so that
    I can get a series of voltages. I have some projects where I
    want simple low part count.
    these units I speak of are at most 200 ma units.
    Some part number help would be nice if any one happens to
    remember..
