Looking for some HP16510B programming info
Discussion in 'Electronic Equipment' started by ajcrm125, Feb 15, 2007.
  1. ajcrm125
    ajcrm125 Guest
    I'm looking to make an app that will convert HP16510B timing info into
    a VCD (value change dump) format. I can get the data from the
    HP16500A, but I need the 16510B programming manual to know what the
    block data format is. Does anyone have one that can scan that secton
    for me? Manuals are like $30+ on ebay and I can't justfy that for
    this simple project.
    -Adam
  2. Keyser Soze
    Keyser Soze Guest
    The portable analyzer 1650B/1651B uses the same analyzer as the 16510B module for the 16500 mainframe.
    The programmer guide is still available on the Agilent server at:
    http://cp.literature.agilent.com/litweb/pdf/01650-90913.pdf
    It may have what you need.
  3. ajcrm125
    ajcrm125 Guest
    Thanks! I'll take a look...
  4. ajcrm125
    ajcrm125 Guest
    Hmmmm I took a look at the data and the manual and it lines up until
    just after the preamble and then it doesn't seem to make sense. I
    have a file's worth of trace data and if I use this format described
    in the 1650B/1651B manual it says none of my PODS are active. :-(
    Guess I still need the 16510B prog manual if anyone has it.
