Looking for replacement Transformer
Discussion in 'Datasheets, Manuals and Component Identification' started by Pslade, Jul 14, 2017.
  1. Pslade
    Pslade
    6
    Jul 14, 2017
    So my Tenma 72-6345 Rework and desoldering station blew. I immediately suspected the transformer. I go in take it out read it and test it. It's blown on the primary side and finished inspecting the unit. Go to find a replacement and I realize it's an overseas can't be found part number or on a shotty site. Can anyone help me find a replacement to this one Chun-Shin PT-025(SL-30) It's
    for the soldering portion. Any help is appreciated.
    Image attached
    http://imgur.com/a/u1M2G
  2. Pslade
    Pslade
    6
    Jul 14, 2017
    Image if it didn't show uploaded
  3. ramussons
    ramussons
    345
    64
    Jun 10, 2014
    A single transformer with those specs may not be easily available.
    A 110 V to 12 - 0 - 12 V @ 2A with an additional 6 V @1 A maybe available.
    Else you may have to go in for 2 transformers with secondaries of 12-0-12 V @ 2A and 6v @ 1A.
    Pslade likes this.
  4. Pslade
    Pslade
    6
    Jul 14, 2017
    You're absolutely right. I had two in mind on mouser's site because there's just none spec'd that way anywhere. Probably something made in house or on the spot. Thank you for the reply. You gave me closure so now I can proceed with the repair.
  5. 73's de Edd
    73's de Edd
    2,776
    1,159
    Aug 21, 2015
    Sir Pslade . . . . .
    Looking at the pristine coloration of your viewable magnet wire windings and the lack of any time related discoloration of the bobbin form . . . .I do fully believe that you just were being the recipient of one SOLID WHACK of line voltage or a lightning hit at your pole.
    Are you up to resolution by inspection ?
    Do a surgical uncovering of the wrap over on the primary side where the BLACK wires make entry into the transformer.
    Let us know what you find, and it would be permissible to use an external 1A fast blow fuse for the blown unit for an initial evaluation of the transformer proper in the interim.
    Also . . . give us the total wattage spec on the power labelling on the Tenma case.
    HOWTODOITTOIT . . . . .
    [​IMG]
    73’s de Edd
  6. Pslade
    Pslade
    6
    Jul 14, 2017
    73’s de Edd I've unwound the the primary and secondary sides after measuring resistance discovering that the primary was burned. There is charred and discoloring on that side as well. Sadly there were no internal fuses in the winding. The station is rated for Power requirements : 120 V ac, 60 Hz, 100 W (24V 48W for each the soldering and de-soldering). Here are some more pictures linked with a shot of the windings and coloration: http://imgur.com/a/q6z9p
  7. kellys_eye
    kellys_eye
    4,279
    1,146
    Jun 25, 2010
    That's one fried transformer!
    Clearly the system is 'under-designed' and the lack of circuit protection is deplorable.
    I'd be inclined to find the aforementioned 12-0-12 transformer AND a separate 6V/1A transformer and fit them in an external case and use a wire/plug to power the station.
    I guess the 6V/1A eventually provide the internal 5V DC for the control circuitry and the 12-0-12 delivers AC to the heating element - clearly UNDERSIZED for a 48W output. You should source a 12-0-12 transformer of at least 3A to prevent a repeat performance - and fit suitable circuit protection whilst at it.
    Pslade likes this.
  8. Pslade
    Pslade
    6
    Jul 14, 2017
    I assumed that Tenma was a huge brand as I seen so many of them in various workshops I worked in of course Hakko being the main brand. But yeah I looked at it and I was just surprised at the design. There are two transformers actually. The one that's blown is to the Soldering iron half and the other is to the desoldering iron and pump. That transformer is fine(for now) and has an additional 25V output. .Image:http://imgur.com/a/kPYHT
  9. kellys_eye
    kellys_eye
    4,279
    1,146
    Jun 25, 2010
    If you could find out whether the AC is used 'as is' or is converted to DC you could then replace the whole transformer/rectifier/regulator section with an SMPS DC supply instead. It may well fit in the case!
  10. Pslade
    Pslade
    6
    Jul 14, 2017
    The transformer outputs AC voltage which is fed to a board with some regs.
  11. 73's de Edd
    73's de Edd
    2,776
    1,159
    Aug 21, 2015
    Meester Burns . . . . . . .
    This is how one of their newer units is being made . . . .
    [​IMG]
    73 de Edd
    Richard9025 and Pslade like this.
Similar Threads
Loading...
