D
DaveC
Looking for a source of pins to connect 2 PCBs.
An obsolete relay needs to be replaced with a modern one with different form
factor and pin layout. The new relay will be mounted to an adapter PCB and
this PCB will be connected to the old relay through-hole pattern via long
solder pins.
I seem to recall pins that have a larger diameter "shoulder" that fit snugly
into a 0.1 inch hole for soldering.
It's these pins that I can't seem to locate. I'm sure it's because my search
terms aren't very efficient.
What are these called? A link to a Mouser or DigiKey page?
Thanks.
solder pins.
Thanks.
