positivebalance41m said:
failing that....looking for design ideas methods to regulate output voltage
despite load current changes.
Typically below 12-15 kw most generators are rpm governed for voltage and
frequency.
Larger units have their own voltage and frequency controls that work to a
tighter level.
You do not mention what your trying to do. If you would describe the
application maybe the group can make some suggestions. Depending on the
application the voltage can vary +10%/-10% and have little effect on most
equipment. Except for the vary sensitive.
I usually set my gen with a frequency meter and 50% load. Voltage at idle
is 130 ish no load. When I start loading it down, the voltage drops to about
120 and everything I plug in is just fine. My gen is a old Pincor 2kw.
