Jon Yaeger
I've got an ATX power supply that I'd like to turn on and off using a
momentary contact switch. I won't be using it with a computer that has a
flip-flop type latch circuit - I'll have to breadboard a simple circuit that
will do the trick.
There is a 5V DC signal available as a trickle supply. The power supply also
has a signal lead with 5V which turns on the unit when grounded. It doesn't
latch on.
To summarize, I want a circuit to latch the power supply on (using its own
5V signal & circuit) when the momentary SPST switch is depressed; and off
when it is pressed again.
Does anyone know of a suitable on-line circuit?
TIA,
Jon
will do the trick.
latch on.
TIA,
Jon
