looking for faulty parts on a JM concept temp indicator .
Discussion in 'Troubleshooting and Repair' started by Elecbegginner, Sep 4, 2013.
  1. Elecbegginner
    Elecbegginner
    103
    Mar 24, 2013
    Hi everybody .
    Today i started looking at a temperature digital indicator .JM concept AK 9200 N .
    I found a bad electrolytic capacitor rated at 100 uF/35V at 105 C° .
    I have a similar working capacitor ( the black one on the card )but the max temp is 85 C° only , so i don't know if its ok to replace with it that ?
    I also need some little help on checking a little transformer , because i don't have the datasheet for it .
    The reason why i want to check the transformer is that it may be causing the cap to get puffy , or maybe other things .
  2. zedsdead
    zedsdead
    6
    Sep 4, 2013
    As far as I understand it you should always replace caps with the same temp rating. They are rated for that temp for a reason. It will work. But for how long is the question. As for your other problem I can't help you there. Sorry.
  3. Elecbegginner
    Elecbegginner
    103
    Mar 24, 2013
    Thanks zedsdead ,
  4. zedsdead
    zedsdead
    6
    Sep 4, 2013
    Sure sorry I can't be of more help. Good luck.
  5. Elecbegginner
    Elecbegginner
    103
    Mar 24, 2013
    The unit is working after replacing the faulty capacitor , i will need to look for one with the right temp rating .
    Cheers
