W
Watson A.Name - \Watt Sun, the Dark Remover\
I'd like to say 'subject says it all' like so many other lamers do, but
it's soooo much easier to just highlight it and copy and paste it into
the body, like this: Looking For: Dual 30-30 @ 600 'Lytic for a Scott
Amp
A friend of mine is fixing a Scott amp and needs a dual 30 - 30 uF at
600 VDC electrolytic, like the old Sprague or C-D twist lock aluminum
cans common in those toob amps. (Notice I avoided that ever so trite
'not uncommon', which should really be the old standard, 'not
unusual').
I have the feeling that it might be easier to clean out the old can and
put a couple individual capacitors inside, or externally. If he were to
use two 60 uF, 350 VDC caps in series for each section, what value
resistor should he put across each of the two caps to balance any
leakags? A hundred k? I see the SMPS caps, which are 220 to 470 at
200V, typically use anywhere from a 330k down to a 150k for the bleeder
resistor. My old Radio Amateur's Handbook shows, for three 100 uFs in
series, a 20k, 10W across each cap. (I don't know why they need to be
that high power, unless a cap were to fail and a lot more of the DC were
to appear across the remaining two caps.)
Any other solutions? Thanks.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
Amp
unusual').
