V
vroemm
Hi..
The signal is a pulse of 337 Khz.
The voltage is 3 volt.
Comming from a source which can give not much current.
It starts to do strange things with loads of less then 50Kohm
The goal is to switch the pin 13 of a parallel port with this signal.
I have been experimenting, with no success.
Does anyone know of a cheap easy to buy component or circuit which can do
this ??
I think its output should be a current source ??
It does not need to give a perfect pulse out.
As long as the pulse can be read by the parallel port.
Thank you very much...
this ??
