looking for "Detent" electrical connectors/contacts
Discussion in 'Electronic Components' started by Tom, Apr 18, 2007.
  1. Tom
    Tom Guest
    I have been looking all over for a some type of connector/contact that
    I can use to connect power between to separate cases that slide
    together. The cases are made of plastic, and I was thinking some type
    of contact that looks like a rivet or screw head (Slightly convex
    head). The contact on the other side would be slightly concave. So
    the contacts would sort of snap together when they are moved into
    position across from each other. This would also prevent the to cases
    from sliding apart, until enough pressure is exerted. I know that
    Milmax and others make a spring version of something similar to this,
    but I would prefer to use the slight flexibility of the plastic case
    to provide the spring action, not to mention keeping the design
    simpler. It would be great if these were simple "push-through" barbed
    contacts. Does anyone know of a supplier for something like this?
    Tom Kuhn
