looking for CS7 Thermostat
Discussion in 'Datasheets, Manuals and Component Identification' started by MECKERT, May 14, 2015.
  1. MECKERT
    MECKERT
    May 14, 2015
    Hello,
    I'm looking for a Clinac (normally closed) thermostat in my
    cofee maker. The marking is "Clinac CS-7S 145 1277".
    Is it correct to deduce that it opens at 145°C approx.? I
    found approaching things, but nowhere found the 1277 marking. What doet it mean ?
    And how to test if it opens correctly ?
  2. poor mystic
    poor mystic
    1,063
    30
    Apr 8, 2011
    Re: "Is it correct to deduce that it opens at 145°C approx.?"
    A teacher of logic would say that it is fundamentally incorrect to deduce any such thing!
    Please excuse any irony in my reply. Errors in characterising electronic components can be fatal - even literally so if bad design is also a factor.
    I used google. I used this keyphrase: "Clinac CS-7S 145 1277".
    The first result was a link to the manufacturer's data sheet.
    To test such a component, I would find some way to suspend it in open air while it is connected to a continuity tester. I would play a hot air gun from about half a meter and watch the tester... come a little closer and again give it time to warm up,,, and keep coming closer until I either get a good result or become disgusted.
