Looking for connectors
Discussion in 'Beginner Electronics' started by Barry, Mar 6, 2007.
  1. Barry
    Barry Guest
  2. Aly
    Aly Guest
    Hi Barry,
    I've been down this EXACT same route as you a few months back, and for those
    connectors too. Very few places do them, unless you're buying by the 1000.
    Your best bet would be to approach a little independant high street computer
    repair shop, as they're used alot in PCs.
    Rapid have some very similar, but you'd need to hack them. Go to "Cables &
    Connectors" then "Multipole."
    http://www.rapidonline.com
    Alison
  3. Barry
    Barry Guest
    Thanks for the advice. It would appear that the type I pictured are no
    longer available. They can be broken to length according to whether one
    wants single, double or more connections.
    As they are solder connections it is easy to move things around during
    development.
    The crimp pins are fine when the final wiring is being done but are a bit
    wasteful when trying things out.
    Anyway looks as though I need to bulk buy crimp connectors.
    Barry
  4. Ross Herbert
    Ross Herbert Guest
    That particular style of pin header socket strip I haven't seen for a
    long time. However, Aries still make it in the pricier collet socket
    style
    http://www.arieselec.com/Web_Data_Sheets/12013/12013.htm
    Those would match up to the male header strip
    http://www.arieselec.com/Web_Data_Sheets/12034/12034.htm
    Aries dip/sip completer product listing
    http://www.arieselec.com/products/dip.htm
    UK distributors listing
    http://www.arieselec.com/distributors/distributors_UK.htm
