Looking for Clarification on Some Things
Discussion in 'General Electronics Discussion' started by supersuit, May 21, 2012.
  1. supersuit
    supersuit
    May 21, 2012
    Item 1:
    I have a power supply which has an output of 12V and 500mA. I need to extend the wire about 15 feet.
    Is it correct to say that I need to use the same guage wire to extend?
    It is my understanding that a heavier guage wire = greater resistence. In turn, this will cause the power supply to work harder to provide the required power over the heavier guage wire thereby shortening the life of the power supply. Is this correct?
    Item 2:
    I have a power adapter which has an output of 12V and 2A. Is it correct to say that I can hook up multiple 12V devices, as long as the total amps required does not exceed 2A?
    Thank you in advance for answering my questions. I look forward to refreshing my memory here.
    SS
  2. davenn
    davenn Moderator
    13,877
    1,964
    hi there
    welcome to the forums :)
    No, heavier gauge = less resistance :)
    yes thats correct dont exceed a total of 2A
  3. alfa88
    alfa88
    344
    5
    Dec 1, 2010
    Perhaps your wire confusion stems from wire gauge numbering. I speak of AWG(American Wire Gauge). Who thought this scheme up? The larger the number the smaller the wire. Ergo the larger the gauge # the more resistance. But then past #1 gauge they change it around and the scale goes to 1/0(1 aught), 2/0, etc. and the higher the aught # the larger the wire. Just remember the bigger the conductor the less resistance. And copper has less resistance than aluminum.
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Brown & Sharpe
    And ironically the AWG has a very close relationship to the resistance of the wire
    http://en.wikipedia.org/wiki/American_wire_gauge
    So it's not based on total nonsense ;)
