Looking for budget spectrum analyzer
Discussion in 'Electronic Design' started by Joe G \(Home\), Mar 18, 2007.
  1. Hi All,
    I am looking for a budget spectrum analyser. Something like this
    http://www.ptsyst.com/3290-B.pdf
    The immediate requirements is use the spectrum analyzer for work with 900MHz
    flea powered transmitter designs..
    Sensitive 50ohm input
    Freq measurement
    Go-No Tests
    Seeing FSK data transmitted data
    Optional monitoring the Tx 3rd harmonic at 2.7GHz
    Any supplier suggestions would be appreciated.
    Regards
    Joe
  2. Phil Allison
    Phil Allison Guest
    "Joe G (Home)"
    ** At around US $3000, that is not exactly cheap for a tarted up radio
    scanner, made in Korea.
    ** So your designs are using the 915 MHz to 928 MHz " all transmitters "
    band with under 3 mW ??
    http://www.comlaw.gov.au/ComLaw/Leg...71B80018AF7A/$file/RadcomLIPDClassLic2000.pdf
    ........ Phil
