Looking for an equivalent diode
Discussion in 'Datasheets, Manuals and Component Identification' started by tommis15, Dec 7, 2014.
  1. tommis15
    tommis15
    20
    Apr 15, 2014
    I am working on fixing a power supply unit. I know it might not work but, better to try than to throw it out. :)
    Anyways I came across a diode called RK-19... it cooked.
    Datasheet at http://pdf.datasheetcatalog.com/datasheet/eic/RK19.pdf
    I can't seem to find this diode anywhere. On the datasheet it says UPDATED: September 12th 1998 so I could only assume it's old and outdated.
    Can someone help me find an equivalent diode... If there is one.
    Thanks in advance!
  2. Harald Kapp
    10,382
    2,267
    Welcome to electronicspoint. I found this one.
  3. tommis15
    tommis15
    20
    Apr 15, 2014
    Thanks for the help... I used a multimeter to check the diode and there is a resistance across the diode... I wonder if I could still use it. Should I still give it a try?
