Looking for a RoboClock-like eval board
Discussion in 'Electronic Design' started by MM, Apr 27, 2005.
  1. MM
    MM Guest
    Hi all,
    Can someone recommend a readily available eval board with something similar
    to RoboClock (Cypress CY7B991) on it? Cypress discontinued them (the boards,
    not the chips), but I need a quick way to try to correct clock skew in some
    test setup... I need it to work at 70 MHz at minimum, but 210 MHz would be
    better...
    /MM
