Looking for a buzzer
Discussion in 'Electronic Components' started by ehsjr, Jun 13, 2007.
  1. ehsjr
    ehsjr Guest
    I need a 16 Vac 7/8" diameter buzzer - electromagnetic,
    NOT a piezo. Any idea where I can get one?
    Ed
  2. Paul Luggar
    Paul Luggar Guest
    I used to work on door entry systems that used AC buzzers like this, may be
    a place to start looking?
    Paul Luggar
    M0SCI
    Website WWW.M0SCI.CO.UK
    Amsat-UK Member 6484
    www.m0sci.co.uk/forum Devon and Cornwalls Amateur Radio Message Board
  3. Al
    Al Guest
    You could make one easily from a small relay. Put the coil in series
    with the relay contacts and your voltage source. Affix a diaphram to the
    armataure to increase the area so that the buzz is louder. It also makes
    a lot of radio interference.
    Al
  4. ehsjr
    ehsjr Guest
    Thanks Paul, I'll try that.
    Ed
  5. ehsjr
    ehsjr Guest
    Thanks Al, I hadn't thought about modifying a relay.
    Might be a good idea.
    Ed
  6. Paul Luggar
    Paul Luggar Guest
    If you use a DC relay on an AC signal it will rattle without modification!
    Paul Luggar
    M0SCI
  7. Al
    Al Guest
    I am using an old GE buzzer, dated 1976, that has three terminals on it.
    A common, a connection for DC voltage, and a connection for AC voltage.
    I traced the wiring and found that the DC route is through a set of
    contacts that are in series with the coil. The AC route bypasses the
    relay contacts as described by the top-poster above. BTW, the packaging
    for this buzzer says it was printed in England. Odd, but maybe the
    buzzer was made in England also.
    Al
  8. ehsjr
    ehsjr Guest
    Yes - but not loud enough. The mod would be to somehow affix
    a diaphram as Al suggested. I wouldn't energize it through
    its own contact - that's likely to destroy the contact sooner
    or later, which would defeat the thing.
    Ed
  9. ehsjr
    ehsjr Guest
    Update - I finally got the buzzer the day before yesterday.
    I found a place that does door entry (thanks to your reply),
    & ordered their buzzer almost two months ago. There was some
    kind of snafu - they thought they had shipped the thing but
    they didn't. Anyway, all's well that ends well. Thanks again.
    Ed
