Looking for a battery holder for a size 13 (or similar) battery
Discussion in 'Power Electronics' started by Sydcomebak, Apr 29, 2013.
  1. Sydcomebak
    Sydcomebak
    Apr 29, 2013
    The battery holder needs to have a top that screws in to turn it on, and unscrew to turn it off. (regular flat-head screwdriver preferred.)
    Anyone seen such a thing?
    Like this:
    [​IMG]
  2. (*steve*)
    25,496
    2,837
    That's not a battery holter, that's a piece if integrated design.
    The PCB (or whatever) underneath and the (clearly) custom case have been designed together to create a battery holder.
    There is no battery holder as such as a component in that camera.
    It looks like a baby Canon.
  3. Sydcomebak
    Sydcomebak
    Apr 29, 2013
    Thanks, Steve.
    I was just looking for that type of housing scaled down to just accept a coin battery with a couple of leads or tabs for hooking up to a circuit.
    -Dave
  4. davenn
    davenn Moderator
    13,833
    1,950
    I personally have never seen stand alone battery holders for coin batteries. The holder is usually either part of the gear casing as in your example or the batteries are soldered into the circuit via lugs on the battery
  5. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
  6. (*steve*)
    25,496
    2,837
    OK. Coca Cola seems to have given you the answer then.
    It seemed like you were after something with a screw-in cover to provide external access.
