C
Chris F.
Don't know if this is the right NG for this or not, but here goes. I've
got a pair of old Kalart-Victor movie projectors (16mm) that I've been
restoring over the past few weeks. Both are from the model 70 series, made
in the late 40's or early 50's. They mostly just needed basic mechanical
repairs - belts, lubricants, etc. Other adjustments, such as shutter timing
and sprocket protrusion depth (how far the two spikes penetrate into the
sprocket holes) were somewhat harder. The motors in particular are an area
of concern. The motors spin at a very high RPM, necessary for the fan to
cool the 1000-watt projection bulb. The motors have brushes which are easily
removed by unscrewing two plastic clasps. The original brushes aren't in too
bad shape, both are about 1/2" long, though one set is just slightly shorter
than the other (more wear on the machine, I assume). I wanted to replace
them with new ones just as a precaution, as I intend to eventually sell one
if not both of the machines. But I could only find company, in California,
that could custom-make these brushes. And at a hefty fee - the setup charge
alone would be up to $60. Not worth it considering I can only get about $100
apiece for these projectors. My question is this; how long could the
original brushes be expected to last, under normal conditions? Are they
reliable enough to sell the machines as working?
Thanks.
Thanks.
