Long time delay
Discussion in 'Electronic Repair' started by M.Joshi, Sep 4, 2005.
  1. M.Joshi
    M.Joshi Guest
    Hello,
    I'm not sure if this is the correct place to post this query but I a
    hoping someone may be able to help.
    I am looking for an accurate way to create a 'one-shot' dela
    adjustable between 30 - 45 minutes.
    People have suggested using a PIC. Is this easy to implement? Ar
    there dedicated I.C's that will accurately do the job?
  2. James Sweet
    James Sweet Guest
    You certainly could do it with a PIC, AVR or any other microcontroller,
    which I would suggest if you're already proficient using them. An easier
    solution would probably be something like the 74HC4060 IC which contains an
    onboard oscillator and a ripple counter, they're often used to get long
    delays. If you go to www.ti.com you can look it up and see the datasheet and
    you can even get a few free samples of the SN74HC4060NE4 they offer if
    you'd like to play around with one.
  3. A 555 connected for monostable start on power up will do this.
    Do a google on NE555 to find a site with the spec sheet which will give
    details of how.
  4. James Sweet
    James Sweet Guest
    A 555 is good for delays of a few seconds to a few minutes, but to get a 45
    minute delay will require a huge timing capacitor and the time delay won't
    be very accurate at all. You really need to use a counter to scale down a
    higher frequency for such long delays.
  5. Jim Adney
    Jim Adney Guest
    You can also buy digitally set time delay relays which you can program
    by little switches on their tops. These cost $50-70, give you a DPDT
    contact set and can be set to delay anywhere from seconds to hours.
    Google on "time delay relay"
  6. Arfa Daily
    Arfa Daily Guest
    This is not strictly speaking, a problem - if you use the CMOS version of
    the 555, from Harris, for instance. This is capable of producing delays from
    " microseconds to hours ", quoting from the Maplin data, for instance. The
    only reason that the bipolar 555 had trouble with large values of caps, was
    the typical leakage of these exceeding the trigger / threshold pins' input
    currents, when large value timing resistors were used to go with the large
    value caps. This limited you to a meg or so and a few tens of microfarads if
    you wanted a stable predictable timer. This is not the case with the CMOS
    version, where the input currents are in pico amps, so you can use large
    value resistors and caps to get much longer delays. In terms of sheer
    simplicity, I'm with Dave on this one, although your clock and divider
    solution is an elegant way of achieving the same result, and one that I've
    used in the past ;-)
    Arfa
  7. Ralph Mowery
    Ralph Mowery Guest
    Another problem with long time delays is how to calibrate the delay. If you
    do use the 555 or similar version then it could take a week to set the time.
    Remember it is 30 minuits between checks. The beter way is to use some kind
    of devider chain so you can set the timer up. He may want to use the 555
    and a 100:1 devider. I have not checked to see what is out on the market
    now but there should be lots of chips that will devide by almost anything.
    Probably running an oscillator very fast and deviding it down will be more
    accurate and maybe easier to set.
    If the device is operated off AC then deviding the 60 hz will be a good
    place to start.
  8. Arfa Daily
    Arfa Daily Guest
    Provided you use a good quality low leakage cap, and high stability high
    value resistors, the delay time should be predictable with reasonable
    accuracy, using the standard 555 timing formula. Shouldn't take more than 3
    or 4 runs to get the time delay down to what you need within a few seconds.
    It seemed to me that the OP needed a 'simple' solution, which the 555
    circuit is, requiring only one resistor and one capacitor besides the device
    itself ( the CMOS version doesn't need either the supply decoupling against
    crowbarring, or the control pin decoupling ).
    This is in contrast to the clock and divider solution, which I accept is
    totally predictable, but requires a divide ratio of 162000 ie 18 bits to
    arrive at 45 minutes,even using a low speed clock such as the 60Hz line
    supply ( which will also need clamping and shaping to form a suitable
    clock ). Also, some ANDing will need doing on the output of the divider to
    get an output at the required time delay. Not as simple as the timer chip
    solution, properly implemented.
    Arfa
  9. You're right of course. I wonder if the U6047 is still available. It was
    designed for things like car heated rear window timing and can be set from
    a few seconds to many hours with standard components - and drive a 20 amp
    relay coil directly with a 12 volt rail. It also gives a choice of simple
    triggering methods. Luckily, I've got a small stock.
    If there's a modern equivalent I'd be pleased to know of it.
  10. James Sweet
    James Sweet Guest
    There's lots of similar chips out there, you reminded me too that yet
    another possible solution would be to use a car window defroster timer, many
    are built right into the buttons and can be had for a few bucks at a U-pull
    yard.
  11. Asimov
    Asimov Guest
    "Arfa Daily" bravely wrote to "All" (05 Sep 05 12:53:28)
    --- on the heady topic of "Re: Long time delay"
    AD> From: "Arfa Daily" <>
    AD> Xref: core-easynews sci.electronics.repair:341392
    AD> Provided you use a good quality low leakage cap, and high stability
    AD> high value resistors, the delay time should be predictable with
    AD> reasonable accuracy, using the standard 555 timing formula. Shouldn't
    AD> take more than 3 or 4 runs to get the time delay down to what you need
    AD> within a few seconds. It seemed to me that the OP needed a 'simple'
    AD> solution, which the 555 circuit is, requiring only one resistor and
    AD> one capacitor besides the device itself ( the CMOS version doesn't
    AD> need either the supply decoupling against crowbarring, or the control
    AD> pin decoupling ).
    AD> This is in contrast to the clock and divider solution, which I accept
    AD> is totally predictable, but requires a divide ratio of 162000 ie 18
    AD> bits to arrive at 45 minutes,even using a low speed clock such as the
    AD> 60Hz line supply ( which will also need clamping and shaping to form a
    AD> suitable clock ). Also, some ANDing will need doing on the output of
    AD> the divider to get an output at the required time delay. Not as simple
    AD> as the timer chip solution, properly implemented.
    AD> Arfa
    The cmos version of the "555" timer is the "7555" and an excellent
    choice for stable delays. I've used one to get a very stable 42
    minutes delay using a poly cap and high value resistor for the timing
    elements. Only problem with the "7555" is the output can't drive as
    much current.
    The 4060 is a nice binary divider chain with 14 stages but it isn't
    the only one. The 4045 has 21 stages for example. However, the nicer
    device is the 4536 which has 24 stages and is programmable. In one
    mode is accepts BCD inputs to control 14 stages. For example, this
    goes nicely with decade trimmer switches which output BCD directly.
    A*s*i*m*o*v
    .... That was a fascinating period of time for electronics
