Watson said:
If you can even _get_ those custom programmed ICs nowadays..
IIRC that's the one radio scrap used to sell, and you needed to use a
3.58 MHz color xtal with it. It put out 60 Hz, or was it 1 Hz? In any
case, it's as rare as hens' teeth nowadays.
Of course, using a PIC12F675, you can do the same thing, fit in an 8 pin package
with a 3 line program in C.
Because it is a custom job, you can take a color burst xtal as your drive source,
and put out anything you want for the timed output....60Hz, 1 pps, 1 pp century...
Power draw is miniscule, like the original.
-Chuck
Standard disclaimer applies, you need some knowledge, and about $50 worth of
programming hardware to make this work.
