Hello guys, this is my first post on this forum. First of all let me say that I know very little about electronics, so apologies if the terminology I use is not accurate.
OK, so this is what I am after. I have an old trackball (Logitech T-RB22 and here is a link http://www.logitech.com/en-gb/support/4751?crid=399) and it has developed a problem:
basically the main left clik button - although it still physically "clicks" - it doesn't register it, meaning that if I click sometimes nothing happens. Now, I have opened that up
and I think the problem was mechanical so have added a piece of folded aluminium foil between the button and the pin that button is supposed to push for the click to happen. It actually worked, it got better but it wasn't perfect, so I have glued another small piece of aluminium foil to is, but unfortunately the glue got inside the connector and the pin got stuck, so now I have to replace it So, here are a few pictures of the connector (I call it connector but who knows what it is) that I need to replace. It is soldered to the circuit so I will have to cut the metal connectors and solder a new one.
The first picture button.jpg is the button that will push the pin of the connector is to generate a click.
Connector.jpg is what I need to replace. The other connector pictures are different sides and in connector2.jpg you can see the infamous pin that is pushed all the way in.
As you can see it has a 456C printed on it, whatever that means, and also there is a white cover on it - it's visible on the right side of the button.jpg - with a code on it that says 002069-0000 cav4
I googled all this but I couldn't find anything. DO you guys know:
-where and if I can buy this component
-once bought if it can be replaced
-if there is anything I have to be careful to when I replace it.
No point contacting Logitech because they don't produce this trackball anymore.
Any idea?
thanks
Any idea?
thanks
