Logik vcr help needed-desperately
Discussion in 'Electronic Repair' started by Mike Muderick, Nov 14, 2005.
  1. I'm lookng for a programming users manual for the Logik LVA 2202., I can
    set up program for recording, but can't figure out the last button sequence
    to get it to go into timer mode. Anyone know where I can find a pdf have a
    copy of this? Or even a fax of the timer recording page. HELP
    thanks,
  2. b
    b Guest
    Mike Muderick ha escrito:
    some of those vcrs were made by samsung in the late 80s. how old is
    your unit?
    -B
  3. I don't know that particular model, but for most VCRs manufactured in
    the last ten years, after you set the timer from the menu, you insert a
    recordable tape and press the power button. Usually a small red LED or
    "timer" display will light up on the VCR's front panel.
    Just be sure it's a new tape or one that is cued up to the place on the
    tape you want to record, and the record-protect tab is intact.
