Categories
Platforms
Content
I would have modelled the B output as B AND (NOT A)
Note that there could be many different answers (even more than usual) because there is one input state where the output is not defined.
Your result seems correct for the three values shown.
I have PIR sensor and the datasheet
You do not need to amplify the output of a comparator. If you only get 1V out, I assume that you have not fitted a pull-up resistor. See the circuit I posted earlier.
Datasheet :
http://www.cytron.com.my/datasheet/sensor/PIR_UserManualv1.pdf
I am asking for what type of application can I make from this.Please suggest to me.
Thank you
