Logic gate
Discussion in 'General Electronics Discussion' started by Avidestroyer, Jan 18, 2013.
  1. Avidestroyer
    Avidestroyer
    21
    Jan 11, 2013
    Can i make logic gate without using relay and transistor?
  2. rob_croxford
    rob_croxford
    262
    Aug 3, 2010
    Diodes
  3. Harald Kapp
    11,702
    2,716
    Diodes work.
    You will need transistors to refresh the logic level.
    See here.
  4. Avidestroyer
    Avidestroyer
    21
    Jan 11, 2013
    Is it possible to make a not gate using diod
  5. BobK
    7,682
    1,688
    Yes, but you need a transistor as well.
  6. Avidestroyer
    Avidestroyer
    21
    Jan 11, 2013
    Since I am a very beginner in electronics, I wanted to make logic gate using only switching circuit. But I can't suscess.
  7. (*steve*)
    25,497
    2,839
    You can do it with switches.
    But we really don't know exactly what you want to do.
    What you're asking is a bit like asking "Can I eat without using a fork?" when what you really want is to know where the best Sushi bar in Chicago is located. The question doesn't help the person you're asking give you the answer you want.
  8. Avidestroyer
    Avidestroyer
    21
    Jan 11, 2013
    I want to make a rs flip-flop circuit using switch.
  9. (*steve*)
    25,497
    2,839
    Easy.
    Use a switch.
    When you push the lever one way, it goes that way and stays that way. Further pushes in that direction do nothing.
    When you push the lever the other way, it goes that way and stays that way. Further pushes in that direction do nothing.
    That is the essence of an SR flip-flop
